Api session event editor building remove
API endpoint to Remove existing Building
| 0 | REQUIRED | (BUILDING Integer ID or multiple values in array [1, 2, 3]) | Building |
| 200 | Boolean (True when at least one item was removed) |
Curl Example POST:
curl=API_TOKENCurl Example multi item POST:
curl=API_TOKEN
