Api session event editor attributeaction set fixed value
Revision as of 08:53, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API endpoint to Set Fixed Value
0 REQUIRED (ATTRIBUTE_ACTION Integer ID or multiple values in array [1, 2, 3]) Attribute Action
1 REQUIRED (Boolean or multiple values in array [true, false, true]) Boolean[]
204 No Content
Curl Example POST:
curl=API_TOKEN
Curl Example multi item POST:
curl=API_TOKEN
