Api session event editor attributeaction set attributes
Revision as of 08:53, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API endpoint to Set multiple Attribute Action attribute values
0 REQUIRED (ATTRIBUTE_ACTION Integer ID or multiple values in array [1, 2, 3]) Actions
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) Attribute Names
2 REQUIRED (Floating point number or multiple values in array [1.0, 2.0, 3.0] or matrix [[1.0, 2.0], [3.0, 4.0], [5.0, 6.0]]) Attribute Values
204 No Content
Curl Example POST:
curl=API_TOKEN
Curl Example multi item POST:
curl=API_TOKEN
