Api session event editor attributeaction append attribute
API endpoint to Appended to existing Attribute Action attribute value
| 0 | REQUIRED | (ATTRIBUTE_ACTION Integer ID or multiple values in array [1, 2, 3]) | Actions | |
| 1 | REQUIRED | (String) | Attribute Name | |
| 2 | REQUIRED | (Floating point number or multiple values in array [1.0, 2.0, 3.0]) | Attribute Values appended to existing values | |
| 204 | No Content |
Curl Example POST:
curl=API_TOKENCurl Example multi item POST:
curl=API_TOKEN
