Api session event editor actionmenu remove actions
Revision as of 08:52, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API endpoint to Remove Actions
0 REQUIRED (ACTION_MENU Integer ID or multiple values in array [1, 2, 3]) Action Menu
1 REQUIRED (MapLink or multiple values in array [a, b, c]) MapLink[]
2 REQUIRED (Integer number or multiple values in array [1, 2, 3]) Integer[]
204 No Content
Curl Example POST:
curl=API_TOKEN
Curl Example multi item POST:
curl=API_TOKEN
