Api session event editor actionmenu remove
Revision as of 08:52, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API endpoint to Remove existing Action Menu
0 REQUIRED (ACTION_MENU Integer ID or multiple values in array [1, 2, 3]) Action Menu
Curl Example POST:
curl=API_TOKEN
Curl Example multi item POST:
curl=API_TOKEN
