Api session event editor zoning duplicate
API Event to Duplicate existing Zoning
| 0 | REQUIRED | (ZONE Integer ID or multiple values in array [1, 2, 3]) | Zone |
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorzoning/duplicate/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'Curl Example multi item POST:
curl 'https://development.tygron.com/api/session/event/editorzoning/duplicate/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 2, 3 ]'JavaScript Example POST:
body: '1'
fetch("https://development.tygron.com/api/session/event/editorzoning/duplicate/", options)
