Api session event editor time set start date
API Event to Set Start Date
| 0 | REQUIRED | (Integer number) | Long |
| 204 | No Content |
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editortime/set_start_date/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '7'Curl Example multi item POST:
curl 'https://development.tygron.com/api/session/event/editortime/set_start_date/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '11'JavaScript Example POST:
body: '7'
fetch("https://development.tygron.com/api/session/event/editortime/set_start_date/", options)
