Api session event editor source add file
API Event to Add File
| 0 | REQUIRED | (String) | String | |
| 1 | REQUIRED | (String) | String |
| 200 | Integer (Integer) |
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorsource/add_file/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "Text", "Text" ]'JavaScript Example POST:
body: '[ "Text", "Text" ]'
fetch("https://development.tygron.com/api/session/event/editorsource/add_file/", options)
