Api session event editor overlay set image
API Event to Change the icon displayed in the navigation window by the Overlay. Only existing Overlay Project Asset are allowed.
| 0 | REQUIRED | (OVERLAY Integer ID or multiple values in array [1, 2, 3]) | Overlay ID | |
| 1 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | Project asset name, omitting the directory |
| 204 | No Content |
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editoroverlay/set_image/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Project asset name, omitting the directory 1" ]'Curl Example multi item POST:
curl 'https://development.tygron.com/api/session/event/editoroverlay/set_image/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "Project asset name, omitting the directory 1", "Project asset name, omitting the directory 2", "Project asset name, omitting the directory 3" ] ]'JavaScript Example POST:
body: '[ 1, "Project asset name, omitting the directory 1" ]'
fetch("https://development.tygron.com/api/session/event/editoroverlay/set_image/", options)
