Api session event editor overlay set discharge method
API Event to Set Discharge Method
| 0 | REQUIRED | (OVERLAY Integer ID) | Overlay | |
| 1 | REQUIRED | (Enumeration) | DischargeMethod | HEIGHT_MINIMA, AREAS or WATER_TERRAINS |
| 204 | No Content |
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editoroverlay/set_discharge_method/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "HEIGHT_MINIMA" ]'JavaScript Example POST:
body: '[ 1, "HEIGHT_MINIMA" ]'
fetch("https://development.tygron.com/api/session/event/editoroverlay/set_discharge_method/", options)
