Api session event editor overlay add overlay function
Revision as of 06:54, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Add a Function to highlight to a specified FUNCTION Overlay.
0 REQUIRED (OVERLAY Integer ID) Overlay ID (must relate to a FUNCTION Overlay)
1 REQUIRED (FUNCTION Integer ID or multiple values in array [1, 2, 3]) Function IDs
204 No Content
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editoroverlay/add_overlay_function/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
Curl Example multi item POST:
curl 'https://development.tygron.com/api/session/event/editoroverlay/add_overlay_function/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, [ 1, 2, 3 ] ]'
JavaScript Example POST:
 body: '[ 1, 1 ]'
fetch("https://development.tygron.com/api/session/event/editoroverlay/add_overlay_function/", options)
