Api session event editor netsetting set owner
Revision as of 06:54, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Set Owner
0 REQUIRED (Enumeration) NetType ELECTRICITY, GAS, HEAT, INTERNET or SEWER
1 REQUIRED (STAKEHOLDER Integer ID) Stakeholder
204 No Content
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editornetsetting/set_owner/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "ELECTRICITY", 1 ]'
JavaScript Example POST:
 body: '[ "ELECTRICITY", 1 ]'
fetch("https://development.tygron.com/api/session/event/editornetsetting/set_owner/", options)
