Api session event editor netcluster remove network
Revision as of 06:53, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Remove Network
0 REQUIRED (Enumeration) NetType ELECTRICITY, GAS, HEAT, INTERNET or SEWER
1 REQUIRED (true, false) Boolean true or false
204 No Content
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editornetcluster/remove_network/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "ELECTRICITY", false ]'
Curl Example multi item POST:
curl 'https://development.tygron.com/api/session/event/editornetcluster/remove_network/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "ELECTRICITY", true ]'
JavaScript Example POST:
 body: '[ "ELECTRICITY", false ]'
fetch("https://development.tygron.com/api/session/event/editornetcluster/remove_network/", options)
