Api session event editor neighborhood set active
API Event to Set Neighborhood active
| 0 | REQUIRED | (NEIGHBORHOOD Integer ID or multiple values in array [1, 2, 3]) | Neighborhood | |
| 1 | REQUIRED | (Boolean or multiple values in array [true, false, true]) | Boolean[] |
| 204 | No Content |
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorneighborhood/set_active/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, true ]'Curl Example multi item POST:
curl 'https://development.tygron.com/api/session/event/editorneighborhood/set_active/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ true, false, true ] ]'JavaScript Example POST:
body: '[ 1, true ]'
fetch("https://development.tygron.com/api/session/event/editorneighborhood/set_active/", options)
