Api session event editor measure set requires confirmation
API Event to Set whether the Measure should be confirmed by other Stakeholder.
| 0 | REQUIRED | (MEASURE Integer ID) | Measure ID | |
| 1 | REQUIRED | (true, false) | Confirmation Required Boolean | true or false |
| 204 | No Content |
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editormeasure/set_requires_confirmation/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, false ]'JavaScript Example POST:
body: '[ 1, false ]'
fetch("https://development.tygron.com/api/session/event/editormeasure/set_requires_confirmation/", options)
