Api session event editor measure set geotiff automatic polygons
Revision as of 06:52, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Let the polygons be calculated automatically based on the GeoTIFFs specified in the GeoTIFF spatial of a Measure.
0 REQUIRED (MEASURE Integer ID) Measure ID
1 REQUIRED (Integer number) GeoTIFF Spatial ID
2 REQUIRED (true, false) Automatic calculation true or false
204 No Content
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editormeasure/set_geotiff_automatic_polygons/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, true ]'
JavaScript Example POST:
 body: '[ 1, 1, true ]'
fetch("https://development.tygron.com/api/session/event/editormeasure/set_geotiff_automatic_polygons/", options)
