Api session event editor measure set description
API Event to Set the description of a Measure.
| 0 | REQUIRED | (MEASURE Integer ID) | Measure ID | |
| 1 | REQUIRED | (String) | Description |
| 204 | No Content |
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editormeasure/set_description/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Description" ]'JavaScript Example POST:
body: '[ 1, "Description" ]'
fetch("https://development.tygron.com/api/session/event/editormeasure/set_description/", options)
