Api session event editor measure remove levee
API Event to Remove specified Levee Spatials from a Measure.
| 0 | REQUIRED | (MEASURE Integer ID) | Measure IDs | |
| 1 | REQUIRED | (Integer number or multiple values in array [1, 2, 3]) | Levee Spatial IDs |
| 204 | No Content |
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editormeasure/remove_levee/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'Curl Example multi item POST:
curl 'https://development.tygron.com/api/session/event/editormeasure/remove_levee/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, [ 1, 2, 3 ] ]'JavaScript Example POST:
body: '[ 1, 1 ]'
fetch("https://development.tygron.com/api/session/event/editormeasure/remove_levee/", options)
