Api session event editor measure add levee polygons
Revision as of 06:52, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Add polygons to existing outer (or inner) polygons of a Levee Spatial of a Measure.
0 REQUIRED (MEASURE Integer ID) Measure ID
1 REQUIRED (Integer number) Levee Spatial ID
2 REQUIRED (MultiPolygon with crs: EPSG:3857) Multipolygon
204 No Content
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editormeasure/add_levee_polygons/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, 1, {
 "type" : "MultiPolygon",
 "coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]
JavaScript Example POST:
 body: '[ 1, 1, { "type" : "MultiPolygon", "coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]} ]'
fetch("https://development.tygron.com/api/session/event/editormeasure/add_levee_polygons/?crs=3857", options)
