Api session event editor geooption set boolean
API Event to Set Boolean
| 0 | REQUIRED | (Enumeration) | Type | AGRICULTURE, BAG3D_GEOMETRIES, DTM_DSM_THRESHOLDS, HEIGHTMAP_RESOLUTION, I3S_GEOMETRIES, IMWA, INTEREST_AREA_MARGIN, NL_AHN, NL_BGT, NL_ENERGY_LABEL, NL_MAX_TREE_HEIGHT, NL_MIN_TREE_HEIGHT, NL_TRAFFIC_INFOMIL, NL_TRAFFIC_INWEVA, NL_TRAFFIC_NSL, NL_TRAFFIC_NSL_CONVERSION, OSM_BUILDINGS, OSM_LANDUSE, OSM_NEIGHBORHOODS, OSM_ROADS, OWNERSHIP, SATELLITE_RESOLUTION, TREES, UNDERGROUND, WATER or WORLD_WATER |
| 1 | REQUIRED | (true, false) | Boolean | true or false |
| 204 | No Content |
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorgeooption/set_boolean/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "NL_BGT", true ]'Curl Example multi item POST:
curl 'https://development.tygron.com/api/session/event/editorgeooption/set_boolean/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "NL_BGT", false ]'JavaScript Example POST:
body: '[ "NL_BGT", true ]'
fetch("https://development.tygron.com/api/session/event/editorgeooption/set_boolean/", options)
