Api session event editor geolink set line buffer
Revision as of 06:50, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Set Line Buffer
0 REQUIRED (GEO_LINK Integer ID or multiple values in array [1, 2, 3]) Geo Link
1 REQUIRED (Floating point number or multiple values in array [1.0, 2.0, 3.0]) double[]
204 No Content
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorgeolink/set_line_buffer/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1.0 ]'
Curl Example multi item POST:
curl 'https://development.tygron.com/api/session/event/editorgeolink/set_line_buffer/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ 1.0, 2.0, 3.0 ] ]'
JavaScript Example POST:
 body: '[ 1, 1.0 ]'
fetch("https://development.tygron.com/api/session/event/editorgeolink/set_line_buffer/", options)
