Api session event editor building add road
Revision as of 06:49, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Add Road
0 REQUIRED (STAKEHOLDER Integer ID) Stakeholder
200 Integer (Integer)
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorbuilding/add_road/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
JavaScript Example POST:
 body: '1'
fetch("https://development.tygron.com/api/session/event/editorbuilding/add_road/", options)
