Api session event editor actionmenu swap order
Revision as of 06:48, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Swap Order
0 REQUIRED (ACTION_MENU Integer ID or multiple values in array [1, 2, 3]) Action Menu
1 REQUIRED (ACTION_MENU Integer ID or multiple values in array [1, 2, 3]) Action Menu
204 No Content
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editoractionmenu/swap_order/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
Curl Example multi item POST:
curl 'https://development.tygron.com/api/session/event/editoractionmenu/swap_order/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ 1, 2, 3 ] ]'
JavaScript Example POST:
 body: '[ 1, 1 ]'
fetch("https://development.tygron.com/api/session/event/editoractionmenu/swap_order/", options)
