Api session event editor trigger set url
API Event to Set Url
| 0 | REQUIRED | (TRIGGER Integer ID or multiple values in array [1, 2, 3]) | Trigger | |
| 204 | No Content |
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editortrigger/set_url/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Text 1" ]'Curl Example multi item POST:
curl 'https://development.tygron.com/api/session/event/editortrigger/set_url/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "Text 1", "Text 2", "Text 3" ] ]'JavaScript Example POST:
body: '[ 1, "Text 1" ]'
fetch("https://development.tygron.com/api/session/event/editortrigger/set_url/", options)
