Api session event editor time set start date
API Event to Set Start Date
0 REQUIRED (Integer number) Long
204 No Content
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editortime/set_start_date/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '86'
Curl Example multi item POST:
curl 'https://development.tygron.com/api/session/event/editortime/set_start_date/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '53'
JavaScript Example POST:
 body: '86'
fetch("https://development.tygron.com/api/session/event/editortime/set_start_date/", options)
