Api session event editor source add file
API Event to Add File
0 REQUIRED (String) String
1 REQUIRED (String) String
200 Integer (Integer)
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorsource/add_file/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "Text", "Text" ]'
JavaScript Example POST:
 body: '[ "Text", "Text" ]'
fetch("https://development.tygron.com/api/session/event/editorsource/add_file/", options)
