Api session event editor sound set loop
API Event to Set Loop
| 0 | REQUIRED | (SOUND Integer ID) | Sound | |
| 1 | REQUIRED | (true, false) | Boolean | true or false |
| 204 | No Content |
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorsound/set_loop/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, true ]'Curl Example multi item POST:
curl 'https://development.tygron.com/api/session/event/editorsound/set_loop/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, false ]'JavaScript Example POST:
body: '[ 1, true ]'
fetch("https://development.tygron.com/api/session/event/editorsound/set_loop/", options)
