Api session event editor overlay set name
API Event to Set the name for a specified Overlay.
0 REQUIRED (OVERLAY Integer ID or multiple values in array [1, 2, 3]) Overlay ID
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) Name for the Overlay
204 No Content
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editoroverlay/set_name/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Name for the Overlay 1" ]'
Curl Example multi item POST:
curl 'https://development.tygron.com/api/session/event/editoroverlay/set_name/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "Name for the Overlay 1", "Name for the Overlay 2", "Name for the Overlay 3" ] ]'
JavaScript Example POST:
 body: '[ 1, "Name for the Overlay 1" ]'
fetch("https://development.tygron.com/api/session/event/editoroverlay/set_name/", options)
