Api session event editor netcluster set scenario
API Event to Set Scenario
| 0 | REQUIRED | (NET_CLUSTER Integer ID) | Net Cluster | |
| 1 | REQUIRED | (SCENARIO Integer ID) | Scenario |
| 204 | No Content |
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editornetcluster/set_scenario/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'JavaScript Example POST:
body: '[ 1, 1 ]'
fetch("https://development.tygron.com/api/session/event/editornetcluster/set_scenario/", options)
