Api session event editor measure set requires confirmation
API Event to Set whether the Measure should be confirmed by other Stakeholder.
0 REQUIRED (MEASURE Integer ID) Measure ID
1 REQUIRED (true, false) Confirmation Required Boolean true or false
204 No Content
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editormeasure/set_requires_confirmation/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, true ]'
JavaScript Example POST:
 body: '[ 1, true ]'
fetch("https://development.tygron.com/api/session/event/editormeasure/set_requires_confirmation/", options)
