Api session event editor measure set grid
API Event to Change the Grids applied by a specified Measure.
0 REQUIRED (MEASURE Integer ID) Measure ID
1 REQUIRED (Integer number) Grid Spatial ID
2 REQUIRED (OVERLAY Integer ID or multiple values in array [1, 2, 3]) Overlay IDs
204 No Content
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editormeasure/set_grid/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 1 ]'
Curl Example multi item POST:
curl 'https://development.tygron.com/api/session/event/editormeasure/set_grid/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, [ 1, 2, 3 ] ]'
JavaScript Example POST:
 body: '[ 1, 1, 1 ]'
fetch("https://development.tygron.com/api/session/event/editormeasure/set_grid/", options)
