Api session event editor measure add
API Event to Add Measure for Stakeholder
0 REQUIRED (STAKEHOLDER Integer ID) Stakeholder ID
200 Integer (Measure ID)
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editormeasure/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
JavaScript Example POST:
 body: '1'
fetch("https://development.tygron.com/api/session/event/editormeasure/add/", options)
