Api session event editor geooption set numbers
API Event to Set Numbers
0 REQUIRED (Enumeration) Type AGRICULTURE, BAG3D_GEOMETRIES, DTM_DSM_THRESHOLDS, HEIGHTMAP_RESOLUTION, I3S_GEOMETRIES, IMWA, INTEREST_AREA_MARGIN, NL_AHN, NL_BGT, NL_ENERGY_LABEL, NL_MAX_TREE_HEIGHT, NL_MIN_TREE_HEIGHT, NL_TRAFFIC_INFOMIL, NL_TRAFFIC_INWEVA, NL_TRAFFIC_NSL, NL_TRAFFIC_NSL_CONVERSION, OSM_BUILDINGS, OSM_LANDUSE, OSM_NEIGHBORHOODS, OSM_ROADS, OWNERSHIP, SATELLITE_RESOLUTION, TREES, UNDERGROUND, WATER or WORLD_WATER
1 REQUIRED (Floating point number or multiple values in array [1.0, 2.0, 3.0]) double[]
204 No Content
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorgeooption/set_numbers/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "NL_BGT", 1.0 ]'
Curl Example multi item POST:
curl 'https://development.tygron.com/api/session/event/editorgeooption/set_numbers/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "NL_BGT", [ 1.0, 2.0, 3.0 ] ]'
JavaScript Example POST:
 body: '[ "NL_BGT", 1.0 ]'
fetch("https://development.tygron.com/api/session/event/editorgeooption/set_numbers/", options)
