Api session event editor geolink set matching
API Event to Match incoming features against this Attribute name and value.
| 0 | REQUIRED | (GEO_LINK Integer ID or multiple values in array [1, 2, 3]) | CustomGeo Link IDs | |
| 1 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | Attribute Names | |
| 2 | REQUIRED | (String or multiple values in array ["a", "b", "c"] or matrix [["a", "b"], ["c", "d"], ["e", "f"]]) | Attribute Values | |
| 204 | No Content |
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorgeolink/set_matching/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Attribute Name 1", [ "A1", "B1" ], "" ]'Curl Example multi item POST:
curl 'https://development.tygron.com/api/session/event/editorgeolink/set_matching/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "Attribute Name 1", "Attribute Name 2", "Attribute Name 3" ], [ [ "A1", "B1" ], [ "A2", "B2" ], [ "A3", "B3" ] ], "" ]'JavaScript Example POST:
body: '[ 1, "Attribute Name 1", [ "A1", "B1" ], "" ]'
fetch("https://development.tygron.com/api/session/event/editorgeolink/set_matching/", options)
