Api session event editor geolink set geometry mode
API Event to Set Geometry Mode
| 0 | REQUIRED | (GEO_LINK Integer ID or multiple values in array [1, 2, 3]) | Geo Link | |
| 1 | REQUIRED | (GeometryMode or multiple values in array [a, b, c]) | GeometryMode[] |
| 204 | No Content |
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorgeolink/set_geometry_mode/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "NORMAL" ]'Curl Example multi item POST:
curl 'https://development.tygron.com/api/session/event/editorgeolink/set_geometry_mode/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "NORMAL", "RADIUS_CENTERPOINT", "RADIUS_CENTERPOINT" ] ]'JavaScript Example POST:
body: '[ 1, "NORMAL" ]'
fetch("https://development.tygron.com/api/session/event/editorgeolink/set_geometry_mode/", options)
