Api session event editor eventbundle add event
API Event to Add Event
0 REQUIRED (EVENT_BUNDLE Integer ID) Event Bundle
1 REQUIRED (true, false) Boolean true or false
200 Integer (Integer)
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editoreventbundle/add_event/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, false ]'
JavaScript Example POST:
 body: '[ 1, false ]'
fetch("https://development.tygron.com/api/session/event/editoreventbundle/add_event/", options)
