Api session event editor cinematic set keypoint time
API Event to Set Keypoint Time
| 0 | REQUIRED | (CINEMATIC_DATA Integer ID) | Cinematic | |
| 1 | REQUIRED | (Integer number) | Integer | |
| 2 | REQUIRED | (Floating point number) | Double |
| 204 | No Content |
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorcinematic/set_keypoint_time/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 92 ]'Curl Example multi item POST:
curl 'https://development.tygron.com/api/session/event/editorcinematic/set_keypoint_time/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 85 ]'JavaScript Example POST:
body: '[ 1, 1, 92 ]'
fetch("https://development.tygron.com/api/session/event/editorcinematic/set_keypoint_time/", options)
