Api session event editor zoning set polygons
Revision as of 12:16, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Set Polygons
0 REQUIRED (ZONE Integer ID or multiple values in array [1, 2, 3]) Zone
1 REQUIRED (MultiPolygon with crs: EPSG:3857 or multiple values in array [a, b, c]) MultiPolygon[]
200 Boolean (Content was updated)
Example POST: https://engine.tygron.com/api/session/event/editorzoning/set_polygons/?crs=3857&f=JSON&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], [ {
 "type" : "MultiPolygon",
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799426.040483224 ], [ 658670.1329758517, 6799426.040483224 ], [ 658670.1329758517, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799428.444194352 ], [ 658738.0624679768, 6799428.444194352 ], [ 658738.0624679768, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799356.752192675 ], [ 658787.631101561, 6799356.752192675 ], [ 658787.631101561, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
