Api session event editor zoning import
API Event to Import Zone Collection
| 0 | REQUIRED | (GeometryCollection with crs: EPSG:3857) | Collection of Zone geometries | |
| 1 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | Zone Names | |
| 2 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | Attribute Names | |
| 3 | REQUIRED | (Floating point number or multiple values in array [1.0, 2.0, 3.0] or matrix [[1.0, 2.0], [3.0, 4.0], [5.0, 6.0]]) | Attribute Values | |
| 4 | REQUIRED | (STAKEHOLDER Integer ID or multiple values in array [1, 2, 3]) | Permitter | |
| 5 | REQUIRED | (true, false) | Import as category Zone | true or false |
| 6 | OPTIONAL | (Floating point number) | Buffer for Points and Lines to make Polygons (optional) | |
| 7 | OPTIONAL | (SOURCE Integer ID) | Source (optional) |
Example POST: https://engine.tygron.com/api/session/event/editorzoning/import/?crs=3857&f=JSON&token=API_TOKEN
with content:
"type" : "GeometryCollection",
"geometries" : [ {
"type" : "MultiPolygon",
"coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799459.159787497 ], [ 658714.3679465037, 6799459.159787497 ], [ 658714.3679465037, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
"coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799316.027611575 ], [ 658761.6546688761, 6799316.027611575 ], [ 658761.6546688761, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
"coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799333.361722283 ], [ 658759.1664923802, 6799333.361722283 ], [ 658759.1664923802, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
}, [ "Zone Name 1", "Zone Name 2", "Zone Name 3" ], [ "Attribute Name 1", "Attribute Name 2" ], [ [ 1.0, 2.0 ], [ 3.0, 4.0 ], [ 5.0, 6.0 ], [ 7.0, 8.0 ], [ 9.0, 10.0 ], [ 11.0, 12.0 ] ], [ 1, 2, 3 ], true, 0.5, "" ]
