Api session event editor unitdataoverride duplicate
Revision as of 12:15, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Duplicate existing Unit Data Override
0 REQUIRED (UNIT_DATA_OVERRIDE Integer ID or multiple values in array [1, 2, 3]) Unit Data Override
200 Integer[] (Integer array)
Example POST: https://engine.tygron.com/api/session/event/editorunitdataoverride/duplicate/?f=JSON&token=API_TOKEN
with content:
[ [ 1, 2, 3 ] ]
