Api session event editor sound set loop
Revision as of 12:14, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Set Loop
0 REQUIRED (SOUND Integer ID) Sound
1 REQUIRED (true, false) Boolean true or false
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorsound/set_loop/?f=JSON&token=API_TOKEN
with content:
[ 88, false ]
