Api session event editor projectasset add
API Event to Upload a new image as a Project asset.
| 0 | REQUIRED | (String) | Directory to upload to | |
| 1 | REQUIRED | (String) | Filename. This should a simple file name, including extension | |
| 2 | REQUIRED | (byte or multiple values in array [a, b, c]) | File data |
| 200 | Integer (Project Asset ID) |
Example POST: https://engine.tygron.com/api/session/event/editorprojectasset/add/?f=JSON&token=API_TOKEN
with content:
[ "Directory to upload to", "Filename. This should a simple file name, including extension", [ 1, 2, 3 ] ]
