Api session event editor overlay set net overlay
Revision as of 12:12, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Set the visualization style for a specified network Overlay.
0 REQUIRED (OVERLAY Integer ID) Overlay ID (must relate to a network Overlay)
1 REQUIRED (Enumeration) NetType ELECTRICITY, GAS, HEAT, INTERNET or SEWER
2 REQUIRED (true, false) Whether to show the network (false means no lines will be visualized) true or false
3 REQUIRED (true, false) Whether only active connections should be visualized (false means both active and inactive connections are visualized) true or false
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editoroverlay/set_net_overlay/?f=JSON&token=API_TOKEN
with content:
[ 4, "INTERNET", false, false ]
