Api session event editor overlay set show difference
Revision as of 12:10, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Set whether a specified grid Overlay has a difference option. If an Overlay has a difference option, an addition output is available computed from the difference between the CURRENT and MAQUETTE outputs.
0 REQUIRED (OVERLAY Integer ID or multiple values in array [1, 2, 3]) Overlay ID (must relate to a grid Overlay)
1 REQUIRED (Boolean or multiple values in array [true, false, true]) Has a difference option (false means there is no difference option for this Overlay)
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editoroverlay/set_show_difference/?f=JSON&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], [ true, false, true ] ]
