Api session event editor overlay set service force xy
Revision as of 12:10, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Set the prefered option to force the CRS order to longitude/latitude for the Service Source of a specified Service Overlay.
0 REQUIRED (OVERLAY Integer ID or multiple values in array [1, 2, 3]) Service Overlay ID
1 REQUIRED (Boolean or multiple values in array [true, false, true]) Longitude first (force XY)
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editoroverlay/set_service_force_xy/?f=JSON&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], [ true, false, true ] ]
