Api session event editor overlay set legend entry name
Revision as of 12:09, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Change the name of a specified legend entry of a custom legend of a specified Overlay.
0 REQUIRED (OVERLAY Integer ID) Overlay ID
1 REQUIRED (true, false) Affect the custom difference legend (false means affect the normal custom legend) true or false
2 REQUIRED (Integer number) ID of entry which should be changed
3 REQUIRED (String) New name for the entry
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editoroverlay/set_legend_entry_name/?f=JSON&token=API_TOKEN
with content:
[ 17, true, 12, "New name for the entry" ]
