Api session event editor overlay set grid active
Revision as of 12:09, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Activates or deactivates an Overlay. Only active Overlay are recalculated by the simulation.
0 REQUIRED (OVERLAY Integer ID or multiple values in array [1, 2, 3]) Overlay ID
1 REQUIRED (Boolean or multiple values in array [true, false, true]) Activated
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editoroverlay/set_grid_active/?f=JSON&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], [ true, false, true ] ]
