Api session event editor overlay set custom legend
Revision as of 12:09, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Set whether the specified Overlay has a custom legend. If the specified Overlay is reverted to use a default Overlay, any custom legend information for the Overlay is removed.
0 REQUIRED (OVERLAY Integer ID) Overlay ID
1 REQUIRED (true, false) Has a custom legend (false sets the Overlay to use the default legend) true or false
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editoroverlay/set_custom_legend/?f=JSON&token=API_TOKEN
with content:
[ 93, false ]
