Api session event editor overlay add legend entry
Revision as of 12:09, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Add a Legend Entry to a specified Overlay. The Overlay must have a custom legend before entries can be added to it.
0 REQUIRED (OVERLAY Integer ID or multiple values in array [1, 2, 3]) Overlay ID
1 REQUIRED (Boolean or multiple values in array [true, false, true]) Add to custom difference legend (false adds the entry to the normal custom legend)
2 OPTIONAL (String or multiple values in array ["a", "b", "c"]) Name (optional)
3 OPTIONAL (TColor or multiple values in array [a, b, c]) Color (optional)
4 OPTIONAL (Floating point number or multiple values in array [1.0, 2.0, 3.0]) Value (optional)
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editoroverlay/add_legend_entry/?f=JSON&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], [ true, false, true ], "", "", "" ]
